3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#1272735 07/16/2018 7:09 PM
Hello All
I just purchased a 3600 1953 truck. I trying to do a stock order of likely parts to have on the shelves as I live in UK. I have checked my engine number and it’s a 216. I want to order a gasket engine set but I can only find 217 listed. Is the 217 the same engine as a 216.
Note I am a complete beginner to Chevy trucks so assume I know nothing.
Regards Chris
Ex Hall Monitor
Ex Hall Monitor
Not knowing where you're ordering I'm assuming they are one and the same. The actual displacement is 216.5ci so both numbers are equally accurate.
This is a product of computerized catalogs. The designation 217 is sort of meaningless but I believe it is a computer roundup of 216.5.
1951 1 Ton Completed
Thanks for the replies. I was just trying to buy a cover all set for my new truck. So I have parts to hand when I encounter problems. If you can see anything else I have missed and likely to need replacing please let my know
Regards Chris
Cylinder head / engine gasket sets
Manifold gasket
Water pump gasket
Front crank oil seal
Rear seal
Gearbox input shaft seal
Plugs
Leads
Radiator cap
Distributor cap
Rotor arm
Rubber brake line
Wheel cylinder brake
Brake adjuster
Note I was not sure if this forum is affiliated with any parts supplier as some forums are. So I did not name the company website I was ordering from. If you can recommend any suppliers who are specialists for my truck please let me know. I’m at the stage where the advise from the supplier is worth more to me than just buying cheapest parts etc.
Ex Hall Monitor
Ex Hall Monitor
Take the "Links" link at the top of the page.
Add a set of points, condenser and rotor to your list. Also, when storing gaskets be sure to store them away from heat and humidity so as not to deteriorate them. eeeek
Welcome to the bolt! The only dumb question is the one not asked.
Chris
Carburetion specialist
At least they didn't list it as a 3.5 litre.
Jon.
The Carburetor Shop
Thanks for the advise on the parts. I got them ordered today and I’m sure I will have many more questions.
My best Regards Chris
