| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Hello All
I just purchased a 3600 1953 truck. I trying to do a stock order of likely parts to have on the shelves as I live in UK. I have checked my engine number and it’s a 216. I want to order a gasket engine set but I can only find 217 listed. Is the 217 the same engine as a 216.
Note I am a complete beginner to Chevy trucks so assume I know nothing.
Regards Chris | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Not knowing where you're ordering I'm assuming they are one and the same. The actual displacement is 216.5ci so both numbers are equally accurate.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is a product of computerized catalogs. The designation 217 is sort of meaningless but I believe it is a computer roundup of 216.5. | | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Thanks for the replies. I was just trying to buy a cover all set for my new truck. So I have parts to hand when I encounter problems. If you can see anything else I have missed and likely to need replacing please let my know
Regards Chris
Cylinder head / engine gasket sets Manifold gasket Water pump gasket Front crank oil seal Rear seal Gearbox input shaft seal Plugs Leads Radiator cap Distributor cap Rotor arm Rubber brake line Wheel cylinder brake Brake adjuster
| | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Note I was not sure if this forum is affiliated with any parts supplier as some forums are. So I did not name the company website I was ordering from. If you can recommend any suppliers who are specialists for my truck please let me know. I’m at the stage where the advise from the supplier is worth more to me than just buying cheapest parts etc. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Note I was not sure if this forum is affiliated with any parts supplier as some forums are. So I did not name the company website I was ordering from. If you can recommend any suppliers who are specialists for my truck please let me know. I’m at the stage where the advise from the supplier is worth more to me than just buying cheapest parts etc. Take the "Links" link at the top of the page.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Add a set of points, condenser and rotor to your list. Also, when storing gaskets be sure to store them away from heat and humidity so as not to deteriorate them.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Welcome to the bolt! The only dumb question is the one not asked.
Chris | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | At least they didn't list it as a 3.5 litre.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Thanks for the advise on the parts. I got them ordered today and I’m sure I will have many more questions.
My best Regards Chris | | |
