1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
My '51 2 ton truck came with a dump grain box . . . and a broken 2 speed rear end shift selector cover. The lower right +/- 15% of the "Two Speed Axle" cover (from the right edge of the W in LOW to about a 3 o'clock position) is broken off. It looks like the cover is either aluminum or pot metal? I have not seen this item in any of my parts catalogs? Any leads on a replacement?
Thanks y'all, Dennis
As far as I know, the only option is used, or maybe nos if lucky. The market of parts for larger truck is weak. Luckily enough, the big bolts share the same cabs as the 1/2-3/4 ton versions making the "general" stuff plenty available.
J. F.
J. F.
THANKS J.F., I was afraid that would be the case.
If anyone has one not being used or knows of a parts truck or a junk yard resident with one on it, I would very much like to discuss purchase and shipment to Texas!!
Appreciate any help, Dennis
Did you try to post in the "parts wanted"?
I'm sure many buy larger truck cab to fix 1/2 ton or so and don't need the selector. Might be worth a try...
J. F.
J. F.
Are you talking about the selector valve that switches the vacuum signal to the rear end? I have a complete valve and the linkage to operate it, not sure of the year of the truck it came from. If I ever make use of the rear end it came with, I'll be using electrical solenoid valves, not the mechanical one. Got a picture you can post?
Sent a pic and price to your email Dennis.
My THANKS to Marty for seeing my post and having a spare he could sell and ship for a great deal!!
Much appreciated and THANKS to all who posted replies.
I find the Big Bolt forum to be full of great folks and much help with my project . . . I SHALL RETURN!!
