2 members (Leo, GRNHydra),
84
Mod | | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | I was thinking of wiring my 12 volt headlights ( when I get that far) in series to make them dimmer for daytime use then switch to parallel for evening lights... any advice? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You’re working on what?ðŸ›
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Seems complicated since all you have to do is turn on the lights while driving. However, there are some LED headlights available with DRLs built in. Might be an option...
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | Ok, so you can understand, I have a honda crv and I like the way the headlights are dimmed as daylight running lights. return to headlights at dusk, or can be turned off if I wish... I don't want to run full headlights in the daytime...or add extra stuff on the front of the pickup, so it is a switching arrangement... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Apparently Beaver Bob doesn’t want us to know what he’s working on. Maybe it’s not in compliance with the site rules? Come on man open up and let us in! ðŸ›
| | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | sorry guys, its a 37 p/u, will be running sans fenders and want the front uncomplicated. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Thanks Bob. Can’t help with your idea but those are cool trucks. ðŸ›
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | I run a pair of Unity fog lights with amber bulbs on my '50, and I turn those on to use as DRLs. I like using them because the tail lights are still off, so there is plenty of contrast between the completely 'dark' tail light lenses and the illuminated brake lights. That's the idea, anyway. Not sure if something similar will fit your uncomplicated front end theme- If I wasn't using the fogs, I'd probably just run the headlights. I'm not sure why they'd need to be dimmer in the daytime, since regular headlights don't seem too bright in the daytime anyway. | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | Should be doable with another switch, or relay. Just a matter of figuring out how to set is up so the headlights are connected in series, then bring in another wire in between them to connect them to ground to make it a parallel connection to go full bright. Or, leave them connected in parallel and switch them to series. | | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | thanks Fire Truck, that is the info I'm looking for..Beav | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | It will be much easier to do if you draw a wiring diagram first, rather than just diving into it. | | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | Agreed, a wiring diagram and a switch with correct poles that will fit the dash is what I'm looking for.. | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | You will probably need a relay with normally open, and normally closed contacts, so with one switch you can switch between the 2 circuits. Might be able to even do it just operating the relay and normally open contacts when the headlights are on, and with the headlights off the daytime lights could be set up to be on with the ignition switch, and normally closed relay contacts. Just try to find the best option on paper.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | You could make it even easier. Purchase the euro style lights for your truck. They make the 7” headlight style with LED blinkers around the bulb. You could make the LED your running light and use the bulb normal.
Just a thought.
Chris | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | You could make it even easier. Purchase the euro style lights for your truck. They make the 7” headlight style with LED blinkers around the bulb. You could make the LED your running light and use the bulb normal.
Just a thought.
Chris Crazy Talk! (before you are offended, see the my earlier post in this thread)
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | After drawing it out myself, it could be done, but you would need to understand the circuit for it to be easy. But, basically you need a 3-pole relay with 2 normally open contacts, and 1 normally closed contact. The headlights could then be connected in series from an ignition power source with a normally closed contact in the series wire between the 2 lights, that would have power feed into the first light through the N.C .contacts with the relay off from the ignition circuit. With the relay on, from the headlight on circuit, then the N.C. contact would open up, and one NO contact would close the ground wire off of the first light, and the second NO contact would close the positive wire feeding the second light making a parallel connection. It's not as bad as it sounds, but you want to really have daytime lights using the original headlights for it to work. I would probably just find some bright LED parking light bulbs, and run those instead, and not a big deal if the tails are on.
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I thought since I brought it up I would post a picture of the circuit in a Ladder diagram, which I find easy to understand. From the ignition switch power it would probably need another relay to carry the lighting current though. http://oi66.tinypic.com/i59l5e.jpg
| | | | | Joined: May 2015 Posts: 11,045 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,045 | I thought since I brought it up I would post a picture of the circuit in a Ladder diagram, which I find easy to understand. From the ignition switch power it would probably need another relay to carry the lighting current though. http://oi66.tinypic.com/i59l5e.jpgNicely done!  The trick on putting the headlights in series for DRL's is genius. They operate at half voltage (and ~1/2 brightness).
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2018 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2018 Posts: 25 | Thank you Fire truck.. this is perfect, I printed it and added it to my stovebolt folder.. I have a couple of options now.. your wiring diagram or the euro headlamps with the running lights in them... I like both options.. you have been very helpful.. Beav | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | my bad gord! that is exactly what I was thinking! I have a pair at home that I may sell in the future.
Chris | | |
