4 members (Hotrod Lincoln, jmoore, NorCal52Suburban, Donf), 183 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
#1272343 07/13/2018 2:57 PM
In my everlasting saga of king pin replacement, I have hit another snag.
The king pin replacement kit I purchased came with metal bushings for the spindles. The bushings fit the pin perfectly but they are too loose in the spindles by a 16th. Is this something that is common and what have you fellas done in the past to correct this?
1950 suburban stock everything.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
A P.O. has had the spindles reamed for oversized bushings. You probably need a pro to help at this point. It may be too far gone unless there is bushings that large. Find a friendly big truck shop or spring shop. I’m sure being in Central Mo there is one close by. Take your spindles and new kingpins to them for advise/service.🛠
This is a common problem with the 1/2 ton.
If it is truly 0.0625” slop you’re likely looking for replacement spindles, or possibly having custom made bushings
Otherwise if the slop isn’t as bad as you describe follow these instructions and fill the gap with a loctite product.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1163785
•1952 Chevrolet 3800 pickup
---All pictures---
