5 members (Hotrod Lincoln, Chip O, greenie-reddy, rfs56trk, ole green), 89 guests, and 10 robots.
Topics128,077
Posts1,056,013
Members48,433
#1271602 07/07/2018 7:35 PM
My father in law just gave me a working OLD aaaooooogah horn that works but I'm sure its 6v. Has anyone used one of these on a 12v system? I'd hate to tear it up since it's a family deal.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Ex Hall Monitor
Ex Hall Monitor
A regular vibrator horn will work OK for short periods of use. I've never tried a 6v klaxon on 12v. If it were me I wouldn't do it. It might be OK but you might fry it too. Maybe someone who's actually done it will chime in.
I just scraped some grime off the label. I think it's a klaxon. No flair on the horn.
I have done it but only very short bursts.🛠
Is there a "reducer" I can use to reduce the voltage to 6v? I've heard of some used on heaters before.
I have one and had to do a little repair on it. The wiring is very fragile and the motor requires oiling periodically. After seeing the guts, I wouldn’t put 12 thru it. It would be cheap and easy to wire in a transformer.https://www.ebay.com/itm/12-Volt-to-6-Volt-Voltage-Reducer-Heater-Blower-Motor-Voltage-Reducer-6V-wiper/171695758294?hash=item27f9dd5bd6:g:WV4AAOSwQJhUjOWk
Don
Can’t begin to tell you how much I hate the name Stovebolt.
Just ordered the reducer.....thanks Don.
that reducer is just a 4-ohm resistor. to drop the voltage from 12v to 6v the load must draw 1.5A. I have no idea what your horn will draw, but if it isn't in that area the 'reducer' will drop a different voltage and your horn may not work. By the way, in operation with 1.5A, the resistor will dissipate 9 watts and will get quite warm - consider mounting it to a heat sink, like the firewall or inner fender.
Crusing in the Passing Lane
I got a large resistor years ago that had exposed wire windings on one side do you could adjust the resistance. Get one, put the tab in the middle of the windings and have a friend measure the voltage when the horn is on, slide the dab to adjust the voltage.
Ed
Do I place the resistor before (battery side) or after the relay (horn side)?
As long as the resistor is in the switched circuit and not the control circuit of the relay, it doesn't matter. Reminds me of when I had starter problems that turned out to be a high resistance connection of the engine ground cable. Swapped out two starters I thought were bad until I found that paint around the bolt where the shop connected the ground cable. Voltage drop is voltage drop, not matter where it occurs.
After the relay, just before the horn, electrically.
Ed
Ok. Thanks.
