8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd),
138
Mod | | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I blowtorched, banged on, oiled and ground the kingpins out of a straight axle. I have a couple of questions:
1. There seems to be a bushing in the axle, my king pin kit didn't come with an axle bushing?
2. Are the spindles right left specific?
1950 Chevrolet suburban. Stock everything.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Oh boy......I hope I do not need to tear apart another axle. Those king pins are a bear to get out.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They're not always difficult to remove.
If a replacement axle beam is the safe answer or the correct answer, don't let the work dissuade you. | | |
