4 members (Barnfind49, cmayna, 1955 1 Series, Phak1), 82 guests, and 2 robots.
Topics128,219
Posts1,057,509
Members48,473
Thinking of swapping my ammeter for a volt meter. Saw the tech tip post that posted a pdf and jpg for a label for a volt meter. I was wondering if anyone had the file(s) for the other gauges as well? I actually already bought the label set from classic parts but having a tough time getting the volt meter label to match exactly. If I could just print them all at once then they would match.
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
1950 Chevy 3100
Your best bet would be to take what you have to a print or sign shop
My wife is pretty good with photoshop but still could not get a match
....example...
That is about where I am at as well. Did you happen to find a matching paint for the internal bezel piece where it says Gasoline, Battery, Oil Press, Temperature?
Jason
1950 Chevy 3100
Awesome. Where did you get the labels to put back on after you painted it?
Jason
1950 Chevy 3100
Wow! Thanks a ton! Do you have a post on this from when you did yours? Your truck looks great!
Jason
1950 Chevy 3100
I did the voltmeter swap and found that the colours didn't exactly match as DADS50 mentioned. I had a new gauge for fuel and temp, used a decal for oil and the print out from the tech tip for the voltmeter. The colours were all slightly different. But once the gauges were installed with the dash lights on or off, it's hard to see any differences. Not an issue for me as I won't be putting my truck in a concourse competition. My bezels were in good shape so I didn't have to worry about refinishing them.
It's a small world, but I wouldn't want to paint it.
Moderated by  ndkid275, Phak1
