4 members (rfs56trk, Hotrod Lincoln, dgrinnan, Otto Skorzeny), 108 guests, and 2 robots.
Topics128,164
Posts1,056,968
Members48,458
I blowtorched, banged on, oiled and ground the kingpins out of a straight axle. I have a couple of questions:
1. There seems to be a bushing in the axle, my king pin kit didn't come with an axle bushing?
2. Are the spindles right left specific?
1950 Chevrolet suburban. Stock everything.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Bushing in axle would be a previous repair. May want to look for better axle beam.
Spindles are same left and right.
Some info on fitting new pins and bushings
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1163785
•1952 Chevrolet 3800 pickup
---All pictures---
Oh boy......I hope I do not need to tear apart another axle. Those king pins are a bear to get out.
They're not always difficult to remove.
If a replacement axle beam is the safe answer or the correct answer, don't let the work dissuade you.
---All pictures---
