0 members (), 86 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
I finally received the correct size insulator block for the Rochester carb for my '55 235 engine., I have the carb to insulator gasket. Do I need a gasket for insulator to manifold? If so, can I just use some gasket compound instead?
BobS46
If it is the same as my 216, there is a gasket that goes between the carburetor and insulator, nothing more. I assume it would be the same since they are so similar. Others will chime in if I am wrong.
Chris
Chevrolet stove bolt engine truck shop manuals show/describe no gasket on either side of the insulator.
If I am incorrect, please post the year of the manual and the page(s).
However, most people use a gasket between insulator and carburetor (with appropriately placed "cut out" in the gasket). A gasket between insulator and manifold is usually not needed, but would cause no harm (unless it leaks).
I would use a gasket between the new insulator and the manifold, as well as a gasket between the carburetor and the new insulator.
The aftermarket insulator is made of a different material than the original one. It appears to be hard plastic.
But I also would recommend the two gaskets for a used original insulator due to slight deterioration common on this 60 year old part made of who knows what.
Carl
Moderator, Electrical Bay
I'm using a bit of inner tube I saved from an old tire I removed. Butyl rubber can be cut to match the flange to insulator gasket, should be fine in this situation and will not lose vacuum. Ask any tire shop to save you an old inner tube. They're not as common as they were 30 years ago, but people still use them. I need to remove another old tire and will see if there's a tube in it. You're welcome to some of this if you want it.
Jon
~ Jon
Thanks all. I had a bit of gasket material and decided to cut my own gasket and plan to install both gaskets without any gasket sealer on either gasket.
BobS46
V
V Offline
Since the new aftermarket insulator I installed was hard plastic (or similar material), I went with a gasket on both the top and bottom surfaces.
When making your gasket, make sure to add a small vacuum hole in the gasket to match the vacuum hole in the bottom of the carb. Roch B's utilize a vacuum actuated power piston to add more fuel to the engine under load. It gets this vacuum from the small hole on the bottom of the carb flange where it bolts to the manifold. You'll notice the OEM gaskets and insulator has this hole and a small channel cut in them for this purpose, just match it.
Good luck
Dave
