1 members (Hush),
73
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, One another question, which thread have the screw which connect the tube from oil pump to engine block? Ask Wolfgang | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The thread in the engine block is a 1/4" NPT (National Pipe) thread. However, there is an adapter fitting that couples it to a piece of 7/16" outside diameter tubing. 7/16" tubing is extremely scarce, so it might be necessary to use 1/2" tubing and the appropriate adapters if you don't have the complete setup from the pump to the block. Going up one size on the tubing isn't a problem. It won't cause trouble with oil pressure, and the volume from the pump won't be affected. Jerry
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, Has someone an idea, where I can buy though screw? Ask Wolfgang | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy wokri, do you have the factory tube which goes from the oil pump to the engine block? | | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Yes, I think it's original. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy wokri, if you have the factory oil tube, then I would post an ad in the parts wanted forum asking for all the fittings to install the tube, hope that helps. | | |
