0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Today I experienced something new! Truck was running great, been driving all morning, stopped for a bit, and while driving to the store, the engine started to run rough 2 Miles from start point. I coasted off the road and she wouldn’t start. (Crank but no pop) thinking I might be out of gas, I filled her up (only 5 gallons would fit in tank). I retried and I fought to keep her running. After about 3-4 minutes of feathering the gas to keep her running, she ran like nothing was wrong. I am stumped! Been running like a old man getting a finger in the butt since and I don’t mean backing into it!
Thoughts? Did I experience what everyone is calling vapor lock?
Chris 1951 3100 with a powerful 216 power plant (insert sarcasm)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely, vapor lock is not your gremlin.
It will be interesting to see other opinions. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | More info: Gas tank was new, new lines/filter - year ago.
Possibility of the float sticking? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Lots of simple reasons, takes time to test. Like Tim said, it's not vapor lock unless you have wrapped your gas line around the exhaust manifold. I will say your day time temps are higher than I thought.
Some possibles: 1. Gas cap not venting 2. Fuel pump 3. Clog in lines, tank pick up, hoses, filters 4. Carb needle valve, float setting 5. Vacuum leak in intake manifold, gasket, hose, tubing, connections/fittings 6. Gas level in tank was too low 7. Loose wire on dizzy, coil, ignition switch or faulty 8. Condenser and/or points 9. Do the easy checks above first, loosen cap, check filters, fill with gas, check vac and wires and report findings 10. Does sound like fuel delivery problem of the type that recovers. I.E. Gas cap, floating debris clog, pump suction. Just a guess. If it gets worse, that's a good thing. Hard to find intermittent. 11. Let's don't do any old man butt jokes.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I’m with bartamos, that comment hits too close to home.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Well, I couldn’t say a rAped ape! :-) FYI, I was a hand puppet once also and your not old.... just experienced!
I am going to start with fuel filter since there is only 12” between bottom of tank and filter. I replaced all fuel lines, tank and fuel pump in the last year. HEI distributed in sept. Gas tank was over 1/2 full. Replaced old gas cap 6 months ago. It has only happened twice today. Kind of weird that this started today when temp was in the 90s. It didn’t do it yesterday with higher temps. Could humidity level have anything to do with it or the extreme rain we had in va last weekend? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I was thinking gas cap first. But is your electric fuel pump acting up? | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | New gas cap and mechanic fuel pump was installed when I replaced the engine. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Next time it conks out on you, look down the carburetor while opening the throttle sharply to see if the accelerator pump squirts out gas. If it does not, then you know that you have a fuel delivery problem for sure. If it does squirt fuel, then you may have a coil problem which only shows up when the underhood temps are elevated. Check for spark the next time it conks out. When I have a fuel delivery issue, I go about it in a systematic manner. 1) Disconnect the fuel line at the at the inlet side of the fuel pump, looking for good fuel flow. Something might be sitting on the end of the pipe inside the tank. 2) If good flow after step 1 above, I do a fuel pump delivery test by removing the fuel line at the carburetor and attach a hose on the end of the hard line, then put the other end of the hose in a 24 ounce Diet Coke bottle (no exceptions unless you are from South Carolina and refer to yourself as a chipmunk, then a Pepsi bottle is acceptable). Then crank the engine with the starter with the ignition off.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Interestingly enough, After warming her up, I took Dad for a 1/2 mile ride to the mail box, the only way I could keep her moving to limp her home was to use the choke cable. I assume by this (prior to troubleshooting) that this would probably lean me towards air/fuel mixture problem. Specifically, lack of fuel since using the choke would decrease amount of air going through the carb.
I will keep you informed as to the findings! Thoughts?
Chris
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | My guess would be clogged carb jets/orifices if pulling the choke helps it run better. That increases vacuum at the venturi so it can suck more fuel thru the openings.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Not sure how it would get clogged. Rebuilt it a year ago when I replaced the fuel lines and tank. There is also a inline filter by the tank. I am going to replace the filter tomorrow and check if fuel is pumping correctly. Once I get to my final location, I will put an inline fuel pressure gauge in which was shipped with all my tools.
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Update: limped the truck home yesterday. Let it cool down overnight, attempted to start it up today. Nothing! A few seconds and she would die. I unhooked the gas, stomped on the starter and got good fuel flow. That should rule out fuel filter and pump. Noticed that my fuel line was touching the radiator hose, so I fixed that.
Other than rebuilding the carb completely, is there another option? Can I reuse the gaskets since I am in Don’s (2ton) country (middle of nowhere Missouri)? Last time I rebuilt it was a year ago at the ODSS homecoming with hotrod Lincoln. Is there an online Rochester B manual that I can’t seem to find?
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Update for 9 July:
Took the carburetor apart, cleaned it all out with carb cleaner (twice). I found a very little sludge in fuel bowl. After it was cleaned, I reassembled everything and cranked it over. She is running like nothing was wrong. Drove 3 miles for test drive, no issues! I will drive farther tomorrow to ensure it is fixed.
Thanks for the help gentlemen!
Chris | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | I had similar issues with my 235. After replacing the fuel tank, fuel line, and rebuilding the carb, it stalled on a very busy road with a load of lumber from HD. Replaced the fuel pump (which apparently had rust in it), and no more problems. | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Chris - hope you have it fixed; but I would do that test drive for about 30 minutes in a circle, so you are not too far from your base.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Crud could have come from a bad tank of gas. I had that happen on a truck one time. The paper fuel filter was slam full of what looked like red clay, a LOT of it. Replaced the filter and was back on the road. What kind of filter do you have? Some are better than others, but some impurities are more fine than others and may get by some filters, and then accumulate in bad places in the passages of the carburetor.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Carbking, thanks for your advice on the phone today. I am going to run back and forth in front of my parents house tomorrow after we go fishing in the morning. Hopefully the sediment in the bowl was causing the issue.
Carl, I have an inline fuel filter 12” from the tank. Unsure the brand. I did however purchase a second see through one that I may put just before the carb.
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Drove about 30 minutes up and down back country roads by lake of the ozarks. She is running like she should be. No issues.
Thanks again everyone! Chris | | |
