4 members (Hotrod Lincoln, fonz8261, Hugh63c10, kbenz), 167 guests, and 3 robots.
Topics128,128
Posts1,056,660
Members48,450
Can anyone recommend a flasher that will work on 6 volt LED lights? I’m trying to flash 3 at a time. The flasher that came with. Would probably work great on incandescent lights.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
Positive or negative ground?
Ordered this one.
https://www.ebay.com/itm/LED-TURN-SIGNAL-FLASHER-RELAY-6-12-volt-3-prong-wire-plug-n-play/253732840395?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Thanks, Don
