| | | Forums66 Topics128,043 Posts1,055,614 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Any chance anyone has a picture of an original jack mounted in a 55-59 3100 truck?
I have the base plate and spring that holds the jack in place but I believe there are a few other brackets that are used to mount the handle and I can not find a picture of where they go.
Thanks | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Got me thinking ? Where did that handle mount ? I would like to know that also ????
59 chevy apache fleetside
2007 dodge diesel 84 toyota 4 runner, v8,propane power
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | see the assembly manual, sect 14 sheet 15 - only bracket is the one for the jack - handle lays on the fuel tank
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Zoom up Click "additional image", then click box in upper right corner.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Thanks Stovebolters you guys are great
