7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 126 guests, and 1 robot.
Topics128,056
Posts1,055,799
#1271140 07/04/2018 2:09 AM
7
7 Offline
My '57 5700 all stock 12 volt system just received a new gas tank and sending unit. I put 8 gallons in to check the gauge, pulled the sending unit twice to adjust the float to read 1/2 tank on the gauge. I'm happy with the results other than the gauge bounces a lot on the test drive, it stays around 1/2 gauge but bouncing. Do others find this normal?
78buckshot #1271142 07/04/2018 2:30 AM
a bouncing gauge is not normal, might be a poor connection that's reacting to vibration - did you put a ground wire from a sender screw to the cab or frame? sure all connections tight and clean of any paint?
78buckshot #1271154 07/04/2018 3:51 AM
What do you describe s "bouncing"?
A slight, low speed oscillation is quite normal with an half full tank slushing around.
A quick bouncing around needle, NOT normal.
J. F.
78buckshot #1271167 07/04/2018 10:15 AM
7
7 Offline
The ground wire is intact but suspect, it is original from the sending unit screw to the cab, I'll replace that. The gauge bounces rapidly, not a slow rhythmic oscillation as one would expect. Thank you for your input as I have no prior experience with this vintage to judge it. I replaced the entire wire from the sender to the gauge and the post on the gauge is clean brass, I'll run a new ground wire to the battery and see if it improves.
78buckshot #1271266 07/05/2018 12:33 AM
7
7 Offline
I ran a new ground wire from the sending unit to the battery, gauge is still jittery but a little improvement. On another note I got the speedometer working today, first time I've seen it move in the two years of ownership, now I have all of the instruments and lights working other than the dimmer for the headlights.
