0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 251 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 251 | I was crawling around under the truck the other day doing the yearly greasing. The rear section of the drive shaft has a sliding section which was looking quite dry just behind the center bearing u-joint. I found the grease nipple for that area but when I pump the grease in it squirts out inside the u-joint while the sliding section remains dry. I would expect to see grease ooze out along the sliding parts but instead its almost like there is a direct path to the outside world from the grease nipple and the grease goes the path of least resistance. So it seems that no lubrication is getting to the sliding part. It does not seem right so do I need to investigate this further?
1950 3600 1951 4400 Gazz
