5 members (Charles in CA, Steelonsteel, Shaffer's1950, 52GMC35424JD, Hotrod Lincoln), 91 guests, and 3 robots.
Topics128,049
Posts1,055,665
A little help please. There are two tee brackets that attach to the frame just below the front bumper brackets on my 1950 3100. What are these for? If you look in the FAM section 14 sheet 1 you can see a portion of the bracket i am talking about.
I'm seeing the top part of the spring shackle on that page (14/1.00) just behind the apron, if that's what you're talking about. It bolts thru the frame with a reinforcement inside the frame C channel. See the upper left figure on FAM Section 2 sheet 5.00.
Tried to send a pic but can't figure out how to reduce file size. I'll keep trying
Your truck possibly had an aftermarket grille guard of some sort at one time? Or fog/ running lights?
These may be left over from one of those?
Jhyp
Email photo/photos to me. I will resize them and attach them to this post.
This is the only thing I saw a "portion of"
Jon's photo is attached below
Not original.🛠
Looks very aftermarket to me. Maybe even a home-built mod. No idea what it would be for. With a single attachment bolt at the frame, it wouldn't be very sturdy.
Thanks everyone. Now I can get rid of them.
Chin spoiler attachment to reduce aero lift wink
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
