Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
A little help please. There are two tee brackets that attach to the frame just below the front bumper brackets on my 1950 3100. What are these for? If you look in the FAM section 14 sheet 1 you can see a portion of the bracket i am talking about.
I'm seeing the top part of the spring shackle on that page (14/1.00) just behind the apron, if that's what you're talking about. It bolts thru the frame with a reinforcement inside the frame C channel. See the upper left figure on FAM Section 2 sheet 5.00.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Looks very aftermarket to me. Maybe even a home-built mod. No idea what it would be for. With a single attachment bolt at the frame, it wouldn't be very sturdy.
