| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Want to update the bushings on the the rear shackles of the front leaf springs. pictures tell me it is a threaded pin. Can someone walk me through the process to remove the pins, bushing and brackets. My shop manual is not specific enough. Do I have to remove the entire spring to press the bushing out or does it come out with the threaded pin? If the spring needs to be removed, can someone walk me through the process on the front shackle. I believe to be the big threaded bolt. | | |
