4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#1270342 06/26/2018 5:16 PM
On the road again
On the road again
Does anyone know if my 15" six bolt wheels will fit on a 57 Chev Truck?
Thanks Jim
Last edited by Jim60; 06/26/2018 9:01 PM. Reason: Removed reference to wheels fitting a car
What size truck? If 1/2 they might fit if the center hole is the right size.🛠
On the road again
On the road again
1957 3100 ….. wheels are currently off my 53 3100 someone wants to buy them, needs to know if they will fit his truck....
Jim60 #1270373 06/26/2018 10:28 PM
62401
There is this thing called a "Tape Measure" ... maybe it would help here? wave
Just sayin'
chug
Measure twice, sell once ... smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Jim60 #1270376 06/26/2018 11:08 PM
Or - - - -you could just try to bolt one on- - - - -
"Here's Your Sign!"
Bill Engvall
On the road again
On the road again
sorry for the misunderstanding....I'm selling the wheels long distance, …….I would bolt one on if I could.....
62401
We're just havin fun blush
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Jim60 #1270426 06/27/2018 12:24 PM
Jim, the more info you can provide in your initial post about what you are trying to do will cut down on the amount of fun our resident jokers, myself included, will have. Sometimes trying to be brief or with holding information in an attempt to sneak something through (car questions) can come back to bite your backside.
To provide more information as far as your question goes............. the bolt pattern will be the same. Center hole and offset/back spacing is still a question the buyer will want answered. Good luck with your sale.
shake
Jim60 #1270429 06/27/2018 12:39 PM
Moderator
Moderator
2 Offline
Jim
Don't let John and Jerry scare you away, they are just a little rough around the edges.
Some things they take for granted and think everyone knows it already.
Try this info on how to measure wheel bolt circle.
https://www.etrailer.com/faq-wheel-bolt-pattern.aspx
The center hub hole is also important and it's diameter should be measured and compared to the buyers hub.
Also the bolt hole diameter.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
The aluminum wheels I currently have on my 53 3100 used to be on a 64 so I would think that they'd also fit a 57 but it would be advisable to get measurements to be sure before you ship them out.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Jim60 #1270480 06/27/2018 10:31 PM
A good friend of mine with a 37 Chevy sedan with the same 6 x 5.5 inch bolt wheel pattern , installed a set of 15 x 7 I think mid-80's Jeep Wagoneer wheels, that look like an old set of polished aluminum slotted Anson Sprints, that look great, and fit perfect, with an old school look too. There are some online, or like new from wheelcollision.com
Jim60 #1270495 06/28/2018 12:24 AM
With the possible exception of the late model Dodge Ram and Dakota 6 lug bolt circle, virtually all the 6-lug wheels will bolt on, including most of the Japanese pickups and the Toyota Land Cruiser. The only sticking point might be back spacing that could interfere with steering tie rods or the drag link. Inside diameter of the wheel barrel might also come into play, affecting brake drum clearance so do some measuring other than just the bolt circle.
Moderator needs to do something about the trouble making ner do wells which sneak in here from time to time reeking havoc and scaring posters...
Jeesh!.
smile
