7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | HI All,
I just recently aquired (and my Son Claimed it's his....) a 1971 GMC longhorn (8.5 ft box) powered by a 350 cid v8, turbo 350 3/4 ton. low milage sat for 20 years, had running in 3 hours, driving in 4.....stopping, until first hard stop blew out a rusty line (not unexpected, will be replacing all the lines and hoses, calipers, wheel cylinders) has split rim 750-16 tyres, looking for a set of non split rim 8 bolts for mounting radial tires on..... needs rockers, cab corners, 1 wheel opening repair and below cargo bedside box door. interior is excellent, radio works! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1958GMCnut, another project, just what we all need. I may have some wheels kicking around here. Missed you at the Pikanik. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Great find, longhorns were rare as hen's teeth even back in the day. Good luck bringing it back to life. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
