0 members (),
103
Mod | | | Forums66 Topics128,095 Posts1,056,494 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | On a 216. Which product do you guys recommend? One side of gasket or both sides? Any other tips? Thanks! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Depends on the gasket. You will need to know what the gasket company says. Many gaskets say NO sealer at all. Use Felpro and search the gasket number for instructions if there are none in the package.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,833 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,833 | It's hard to go wrong with a brush-on liquid sealer like Permatex Super 300. I've been using it for close to 60 years so far without any problems. Jerry
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | a thin layer on the pump side of the gasket if nothing else to keep the gasket from being misaligned while the pump is being mated to the block. I haven't had any problems so far.
1949 Chevy 4400 216
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | OK, thanks for the help! Jim | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | I don't like to speak badly of a product, Jim but please don't use Indian Head shellac sealer. Once your engine heats up, this stuff will melt, run out of the joint and then the seal will fail. I'd use what Jerry suggested or the Permatex Aviation sealer. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Jim,
Permatex makes a sealer specifically for your application. It's called Water Pump & Thermostat Housing Gasket Maker. The part number is 22071. Although it can be used instead of a gasket a light coating on both sides of a gasket seems to work really well.
I found out the hard way to NOT use Permatex Hylomar HPF to seal coolant.
Ray
