2 members (DHedrick, WarEagle1), 103 guests, and 3 robots.
Topics128,087
Posts1,056,375
Members48,442
** I'm not sure on the clamshell seals install on my 53 Suburban. ** Does the seal go all the way around on {all four sides} top clamshell & only on three sides on the lower clamshell??? Thanks For The Help.
On our 52 Chevy Carryall, we used the seal on all four sides of the upper clamshell, and on three sides of the lower clamshell. I'm not sure if this is correct, but it worked well for us.
Thanx!
Lisa
1952 Chevy Carryall in completely original condition
Pulled out of a barn in Colorado high desert
** That is what I thought. I went ahead and installed the seals as mentioned but have not installed the clamshells yet. The seals sure look correct installed that way. Thanks for the reply.
