| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | hey guys what is the the best way to place a cab in the bed of a pick up to transport? should i build a stand to keep the cab off the floor? moving it 1100 miles... need ideas, quick thanks raf | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | stack a couple of pallets, enuff to keep the weight off the quarters - fit great, strong, cheep
Bill | | | | | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | will that keep it off the wheel wells of my bed? raf | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Be careful how you tie it down - easy to bend or pull things out of alignment | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Its best if you can leave the doors on it, and lock them. Else, weld x-braces across the door openings before you pull it from the frame.
