7 members (Shade Baby, 68ironhead, rinemb, Otto Skorzeny, elhippie64, Gdads51, 1 invisible), 214 guests, and 3 robots.
Topics128,095
Posts1,056,075
Members48,433
I want to use the cigarette lighter in my 56 Chevy pickup to operate GPS/cell phone. The truck has a generator and I've read that that can cause problems for devices like GPS and cell phones. I just wanted to get the opinion from the guys on the forum. Bad idea? Will it ruin an electronic device? 12 volts, by the way.
1956 Chevy 3200
I picked up a charger that’s also a volt meter
Similar to this type
...link...
I have the hot lead to the charger fused
Others can advise about the generator issue.
DC generators produce a "noisy" voltage signal that might confuse a digital device and make it perform erratically, but I don't think it would damage it in the process. I'd suggest installing a small auxiliary battery such as one of the the gel cell batteries used to power a kid's ride-on toy or something similar, and wire a power port to that. You could get several days' worth of use from a cell phone or other device before the battery would need recharging. A simple toggle switch could be used to isolate the second battery from the generator while electronic devices are in use.
Sir Searchalot
Sir Searchalot
If the GPS is on the cell phone, check your cell phone once in a while to see if it needs charged. Then charge it at home. Life is not that difficult. If you go on a long 8 day trip, charge it in the hotel room.
Leo Offline
Moderator
Moderator
A few weeks ago my electricity was off for 13 hours due to an ice storm. The only way I could charge my phone was in my old truck, in the cigarette lighter. On my trip to the homecoming I used it as well, no problems.
Sir Searchalot
Sir Searchalot
If 1953 panel has a generator, there's your answer.
Was the engine running at the time of charging 1953 Panel?
Thank you, 1953 panel
Other people have posted the same results. They have posted that USB charging adapters work fine in 6v-powered cigar/cigarette sockets. I am somewhat of a doubting Timoth, so I will eventually test this with an old/semi-lame iPad in my 6v Suburban.
People have reported powering iPhones/iPads/GPS via a USB adapter in their 6v socket.
Leo Offline
Moderator
Moderator
yes, I'm running a generator, 12v.
Leo Offline
Moderator
Moderator
Not at home when the electricity was off.
Still keeping Old Blue my '50 3600 bone stock, which means it's still got the 6v generator and
6v electrical system.
I use the lighter socket for my TomTom GPS regularly as most all of the solid state devices
actually only need 6v to operate them. Works like a charm. However, the Sony radio/cd player
needs a voltage cube to up the 6v to 12v as does my SunPro tach.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
