2 members (stlcardinalsguy, PAUL Berardi), 134 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
After reading multiple postings about the Remflex gasket, I ordered one for my 261 rebuild. The gasket thickness is approximately equal to the depth of the intake manifold rings that protrude from the head. Because of this I have been unable to get all 3 rings to mate to the intake manifold openings. I'm curious as to how others have made everything line up without the manifold rings protruding past the gasket.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
I jut finished mine. I left the rings tick out a little and they seated up fine when it all went together. Can’t say if my gasket was as thick though.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
I put the rings in the head and gently installed the intake, jiggled it just a bit to make sure the rings lined up. I had the same issue you did installing the rings in the intake and trying to get the rings to line up with the head.
Mike
You could temporarily remove the front and rear studs in the head and replace them with long alignment studs made out of bolts with the heads cut off.
This should help align the manifold to the head so that the alignment rings will go in as the gasket compresses some.
Thanks for the help everyone. Following Dragsix's lead, I moved the rings from the head to the manifold, then using masking tape I positioned the gasket in precise alignment against the head. After that it wasn't too difficult to get the manifold lined up and install the bolts. I'm getting closer to firing up my new engine. Just need to turn it to TDC, install the distributer, and mount the radiator on the engine dolly.
Oldbolter
Outstanding! I have had very good luck with those gaskets and prefer them over the stock style.
Mike
Crusing in the Passing Lane
They sound great, however they do not make them for a 503, got some Remflex stock, tried normal gasket making procedure, product would not hold together.
Ed
