9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible), 57 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1267707 05/31/2018 8:35 PM
Hello,
How easily should a crankshaft rotate, which was re-used with the pistons?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Crusing in the Passing Lane
New rings? New crank seals?
Ed
wokri #1267762 06/01/2018 10:25 AM
Hello Ed,
no the pistons rings has running, the crank seals on the rear side are new.
wolfgang
wokri #1267767 06/01/2018 11:54 AM
If you just added a new rear seal, it would be hard to measure the difference. Normally, when the crank is out, the main and rod bearings are measured and cleaned up with a piece of fine emery cloth if just need polishing, otherwise ground to the next undersize, rods are reconditioned, bore measured and if worn, bored to the next oversized which requires new pistons and rings. This is all normal and not overly expensive, at least in the 'states.
Measuring rotational drag is not a good measurement of engine health. I am sure there are machine shops in Germany that are familiar with this procedure. Good luck.
Ed
wokri #1267773 06/01/2018 12:55 PM
Hello Ed,
the main bearings 40 undersize are new, the crankshaft is poished to '40 undersize.
Wolfgang
Wolfgang, you should experience some drag with the spark plugs out. It should not spin easy but it shouldn't take too much force to turn. If your talking just the crank bolted into an empty block and torqued properly, there should be minimum resistance and no slop that you can feel. there will be some measurable end play. Check specifications in the shop manual. Good luck.
You need to isolate where the drag is coming from. Are you able to check the rotation of the crankshaft without the connecting rods attached to the crankshaft?
wokri #1267991 06/03/2018 12:37 PM
Hello,
I took off the cranlshaft and the rods and shaw that two bearings were damaged. Why I don't know, I used a special grease for connecting different motor parts and there must be particles in it which damaged the bearings. And annother point could be that, there was no space or very small between the crankshaft and the mainbearing caps. So I have to look why.
Wolfgang
Do not use grease on rod, main and cam bearings during installation. Only motor oil. Just my opinion.
Yes, I see it meanwhile also.
