| | | Forums66 Topics128,155 Posts1,056,868 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | Hello, Long time reader, first time poster. I've got a very stock 1951 3600 truck that I've enjoyed driving and working on but would like to get some higher speeds out of. I assumed the options being a 3/4 ton were: Rear end swap - Pat from Patrick's suggested a 3/4 Ton Ford rear end that's minimal hassle to swap and fits original wheel bolt pattern. Overdrive transmission swap. ( It's got a 4 speed Muncie on the floor in great condition and I still enjoy double clutching for the original "feel.") But I'm curious if anyone has found a carrier or ring / pinion setup that would fit so I could truly keep everything looking stock on the outside. Here's the post that teased me: Kip Bonds' 1941 3/4 Differential Swap | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Kip's truck is the lighter duty 6 lug. So that swap really wouldn't apply to you. There are 4.10 center chunks out there for your rearend, though are more and more difficult to find. If you're going to swap the whole axle, an 8 lug Dana 60 would be a good choice and are found in Chev/GMC, Ford and Dodge, which all have the same 8 lug pattern. Ring and pinion sets are also readily available. Dodge 3/4 and 1 ton vans usually have nice ratios like 3.54 and a lot have limited slip as well. They are usually about 65" wide at wms. A little wider than your stock axle, but can be made to work. Pre-1974 these axles are usually a bit narrower and closer to your stock width. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd look first for the 4.11 gears for your existing rear. They are hard to find and you may quickly give up, but since they are the most stock looking and the easiest swap, I'd at least give it a shot.
After that decide if you'd rather deal with changing rears or changing transmissions.
A downside of changing to the T-5 trans is that it is not a heavy-duty transmission. If you actually load this truck I'd suggest leaning toward the rear axle swap. And if you load it heavily you need to ask if the trade off of more speed for less grunt will work for you.
If shifting a 5-speed sounds better than swapping rears go that way, otherwise look for an 8-lug rear that is real close to the stock width and swap. While you need to make sure tires don't rub and that the rear fits under the spring and frame, and the actual width measurement is not as critical as many other things are.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | Thanks Fellas! The hunt is on. :0) | | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Hi - The original rearend should be an Eaton HO52. The Eaton HO52 and HO72 rearends were also used in 1967 through 1972 Chevy/GMC 3/4-ton trucks and are a direct swap/interchange. I picked up a 4.10 ratio carrier/rearend by shopping the classifieds at: www.67-72chevytrucks.com . When I rebuilt my rearend on my '49 Chevy 3600, I found out that the bearing are barrel-shaped and seemed a bit pricey. However, overall, I like the stock appearance of the Eaton HO52 rearend. Good Luck! Dan M. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No need to get stuck with the 4.57 or 5.13 rear gears either. 4wd guys would happily take em off your hands. | | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | Fantastic guys! Finding a little more modern vehicle that holds the same carrier is invaluable. You'd think it wouldn't make a huge difference but doing web searches or asking people on the phone brings up a blank silence or search if you use the 1951 Chev 3600 criteria, but saying a '68 Chevy C20 gets a completely different result. :0)
I believe I have the 4.57 gears. What kind of increase in cruising speed could I expect going with 4.10? I consider 45 mph comfortable right now and would be overjoyed to get 55 mph if possible. :0)
Thanks again. What a great reference this place is!
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 55 should be pretty doable. You may want to use a gear calculator, but I believe at 65mph your engine would be just under 3000rpm, depends on tire size. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The change would be close to 10% or (4.57 - 4.10)/4.57 = 10.28 %. So your RPM would be roughly the same at 50 mph that you now have at 45. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Webster, yep, you could cruise along at 55 mph just fine with the 4.10 and your stock 216 babbitt pounder. I’ve been running that gear for a couple of years now in my other wise stock 1950, 3604 and it’s great. I’ve put about four or five thousand miles on the old gal since I swapped the gear. On the rare occasion where I might need to pass a REAL slow poke I do kick her up to 65 mph but don’t hold it there for very long. I’m able to cruise down the tollway now as long as I make sure I stay in the far right lane. It’s a straight exchange, just clean things up good, reseal and bolt the new one in. dg
Denny G Sandwich, IL
| | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | Thanks Gentlemen.
It's funny how there's pockets of information out there and you can look for months chasing down cold leads, shift a little and run into a whole bunch of people that have already been there / done that. :0) | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Webster, somethin' like fishin' isn't it. Denny Graham Sandwich, IL
| | | | | Joined: Jul 2010 Posts: 21 New Guy | | New Guy Joined: Jul 2010 Posts: 21 | I have a 1949 4400 with 6.17 gear ratio. Any suggestions for my situation? | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Speaking from the perspective of an old dirt track racer who used a lot of those HO72 4.10 gearsets back in the late 1970's (one reason they're so scarce now), the ring gear carrier has a different side spacing, so it must be changed along with the ring and pinion. If you can find the Detroit Locker center section as well as the gears, grab that, too. They're a little noisy in turns, but in a slippery situation, the pulling power is awesome. Jerry
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | AlexJ in Virginia helped me change my 1953 3600 from 4.56 to 4.11. Took under two hours. He sometimes has one of the center sections on hand, and has done the swap many times. If he has one, he can ship it at a reasonable price and talk you through it. You might want to PM him. Just a thought.
Harry | | | | | Joined: Sep 2013 Posts: 1 Moderated | | Moderated Joined: Sep 2013 Posts: 1 | I have a chevy 3600 1953, and I want to change the crown and pinion differential to 4.11, to get more speed. They know site online where I can buy them?
| | | | | Joined: Oct 2017 Posts: 11 New Guy | | New Guy Joined: Oct 2017 Posts: 11 | I have the same truck as Juan and I have the same question. Where can I find a third member from a 69-71 Chevy pickup? Any suggestions? Bob | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | I have an identical truck. sorta. I have a 51 3600 series 3/4 ton. I took the complete differential from a 72 3/4 ton and installed it. 3:55 ratio. it's a bit wider and I had to open up the center bolt holes a bit, but i'm very happy with the result. 70 mph with tall tires and a 235 engine. | | | | | Joined: Nov 1995 Posts: 5,732 24601 | | 24601 Joined: Nov 1995 Posts: 5,732 |
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | This is one of the best links for finding a pumpkin.
Ownster.com
They throw craigs list, Ebay and a few others in your search results. This is how I found mine.
Also don’t just try to find the pumpkin. Rolling chassis‘ are also a source. Just ask for the pumpkin. That’s what I did. Find someone selling a frame or part of a truck. And don’t let anyone here kid you. They are hard to find unless your in the north.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | any 4x4 rear axle off a chevy truck post 1975
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
