3 members (Wayne67vert, Peggy M, klhansen), 53 guests, and 2 robots.
Topics128,154
Posts1,056,851
Members48,456
Does anyone have a profile or source for the rear splash apron to rear bumper seal?
** Is this the splash apron seal you are looking for? ** Part # MMS235 from Jim Carter ** Price $17.50 **
When I last searched, only a fiberglass 47-55st panel-body rear splash apron was available.
As posted above. Jim Carter Truck Parts, and maybe others, sell the seal.
** Orig. splash apron on Ebay, a little on the pricey side but it's been there for a good long while & seller is asking for offers. Ebay # is 382379707689
Lol! I don't know why, but I didn't even think to check Jim Carter. Thanks!
Yes, that is it - mis-labelled: it fits 47-55st series panel-body Chevrolet and GMC trucks.
Leo Offline
Moderator
Moderator
I got lucky, found mine at a flea market for $5.-
Bondo Artiste
Bondo Artiste
The seal from Carter is a perfect fit for the original, steel rear gravel pan. To make it fit the aftermarket fiberglass rear gravel pan you have to glue it, as the fiberglass panel does not have the groove in it to run the seal. It’s a great seal.
~ Phillip
Thanks Phillip.
After looking at a few panel/Suburban rear pans, I've noticed that some have the groove for the rubber seal while others had no groove and the seal was factory stapled on, much like the rubber seals are stapled onto AD inside window trim.
1951 Chevy Panel Truck
