4 members (Gray_Ghost, Shade Baby, WarEagle1, Jon G), 114 guests, and 2 robots.
Topics128,102
Posts1,056,184
Members48,436
#1266611 05/22/2018 3:18 AM
Looking for advice on rebuilding my 235. Does anybody have any suggestions of upgrades or tech tips? Already planning on having it balanced and replacing the fiber camshaft gear with the metal type, installing a oil filter kit. Looking to keep it as stock as possible.
1959 3204 Basic Cab
Wrencher88 #1266620 05/22/2018 12:07 PM
Have the crank snout drilled and tapped for a balancer bolt. Allows the use of a regular balancer install tool instead of a block of wood and a hammer. Send your distributor out and have it professionally rebuilt.
Mike
Wrencher88 #1266621 05/22/2018 12:29 PM
Have the head Magnafluxed as they are prone to cracks. drive
Check out Deve's Rebuild page.
It's a small world, but I wouldn't want to paint it.
All great ideas, totally forgot to look at Dave's Rebuild page, thank you!
1959 3204 Basic Cab
Moderator, Electrical Bay
J Online: Content
While it was out I would see if anyone near you could machine the block to accept a one-piece rear main seal. Also, I would buy a harmonic balancer repair sleeve and install it. Even if you center that seal perfectly and polish the balancer sleeve nicely, it can still leak. One other thing...if you're handy with metal working (1/8 inch aluminum will do) make a bar for the lower side of the pushrod cover so it will seal better.
Good luck,
Jon
~ Jon
Wrencher88 #1267014 05/26/2018 12:57 AM
Another thing to consider. As you can see, Chevy had an odd way of retaining the timing cover to the block. Mostly screws, although sometimes bolts, from the outside, but two bolts and a retainer from the crankside side of the motor. I have no clue why they would do it that way, maybe a sale on pan gaskets or something. What this means, is if the timing cover leaks you have to pull the pan to get to those two bolts in order to replace the gasket.
A really old modification, tap the front main cap for threads, i forget offhand what size they are, 3/8-18 maybe but not certain at the moment (the holes in the cap are close enough to the correct drill tap size to do it), and drill out the timing cover and plate to oversize, so that you can install all of the bolts from the outside. I have done this to a majority of the motors I have built. Had a timing cover gasket fail just once, with the most recent 261 build. Boy, was I happy. Only had to deal with the front of the motor, and did not have to pull the pan to do it.
Mike
Wrencher88 #1267047 05/26/2018 11:30 AM
