| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | Is there any significant differences between the 1/2 ton and 3/4 ton frames for the years 64-66? I want to swap the suspension and drive train from a 1/2 ton to a 3/4 ton. I have a 1965 3/4 ton with a title that is in very good shape and a 1964 1/2 ton parts truck that has the complete suspension and drive train I would need.. Both of these trucks are 127 inch wheelbase. I plan to shorten the frame also to make it a short bed. Thanks for your help! | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Every thing will swap over. The 3/4 ton frame will be a little thicker than the 1/2, but everything will swap
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | | | |
