3 members (DES57, 2-Ton, 1 invisible), 102 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
Hello,
I have two questions, if I tighten the srews of bracket that hold the camshaft to the cylinder block, than I can't turn the camshaft.
https://www.kripahle-online.de/unterricht/wp-content/uploads/2018/05/IMG_7952.jpg
What do I wrong?
And one another question, what do I fix with this srew?
https://www.kripahle-online.de/unterricht/wp-content/uploads/2018/05/IMG_7953.jpg
The block number is GM 3835911
Asks
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Wolfgang, I cant tell from your description whether the cam wont move at all or it gets stopped by the screws. I also can't tell from your photo but are those bolts you are using to hold the cam thrust plate to the block instead of screws? It should be held in place with a pair of pan head phillips screws and internal star washers. Also, you are using the thrust plate and the spacer ring correct? So if you are using bolts and the cam gear is catching the bolts, switch over to the pan head screws. If you are using the correct screws, and the thrust plate and spacer, I wonder if you installed the rear cam plug in too deeply and when you are tightening the thrust plate, it is causing the rear cam journal to compress against the rear cam plug?
Mike
Do you have the plug at the rear of the cam in? That plug is very shallow because the camshaft comes close to it.Some vendors sell a plug that is much too deep. If one of those was installed, the camshaft would bind on it.
1951 1 Ton Completed
' Offline
Camshaft Thrust Bearing Screws are available from Chevy of the 40's for $1.50 .
https://s26.postimg.cc/t26503vmh/Chevy_Parts_Camshaft_Thrust_Bearing_SCREWS.jpg
Camshaft Bearing Hole Plug
Early Models Chev. 1937 to 1954 - ( with small journal camshaft )
GM # 0.553 - GM # 838127 - Diameter 2 " inches
GM # 838127 is available GM NOS
Collectors Auto
Blaine, WA.
phone: 800 - 414 - 4462
Collectors Auto has ( 3 ) in stock
1954 / '55 / '56 / '57 Chev. 6 cyl. ( with large journal camshaft )
GM # 0.553 - GM # 3704158 - Diameter 2 & 1/8 " inches X 1/4" thick
https://s26.postimg.cc/8jfu8jeq1/Camshaft_Bearing_Hole_Plug_GM_NOS.jpg
The Plug is available GM NOS
Friesen Chevrolet
Sutton, Nebraska
phone: 402 - 773 - 5538
Friesen has ( 51 ) plugs in stock
Dan's GM Obsolete
Chinook, Montana
phone: 406 - 357 - 2615
Dan's has ( 23 ) plugs in stock
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
I have installed that plug a few times lately. The early plug is actually 1 31/32" in diameter and the depth is around 3/16".
