7 members (HandyAndy, gswbbc, baldeagle, tclederman, 57 Drifter, Cosmo, 1 invisible), 149 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
My truck is what I believe to be a Chevy 4400. Will that have a 1.5 or 2 ton axle. How can you distinguish between the two?
I saw an axle locally on Craigslist that is from a ‘53 6400 that the guy is calling a 2.5 ton axle. Is that correct or would that be the 2 ton axle I would need? (for the P-30 spindle/brake swap)
Any suggestions on how to ID different axles?
First look in your shop/service manual.
It will describe and show different front axles and will also give specifications (usually at end of the section) for king pin diameter and so on.
For the 48-54 trucks, and likely a few years either side, the 1.5 ton axle is based on the 3/4 and 1 ton axle beam with same king pin but different hubs and brakes.
The 1.5 ton axle has a screw on dust cap over outer wheel bearings.
The 2 ton (and 1.5 ton heavy duty) axles have a thick flying saucer like dust cap held on with 5 little hex head screws. These axles also have 1.109" kingpins.
This only for 1.5 and 2 ton Chevy and for most GMCs of same size. Not speaking to GMC's larger trucks which could have even more different different axle options.
1952 Chevrolet 3800 pickup
---All pictures---
Thanks for the help Grigg!
