| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I want to use the cigarette lighter in my 56 Chevy pickup to operate GPS/cell phone. The truck has a generator and I've read that that can cause problems for devices like GPS and cell phones. I just wanted to get the opinion from the guys on the forum. Bad idea? Will it ruin an electronic device? 12 volts, by the way.
1956 Chevy 3200
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I picked up a charger that’s also a volt meter Similar to this type ...link...I have the hot lead to the charger fused Others can advise about the generator issue. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | DC generators produce a "noisy" voltage signal that might confuse a digital device and make it perform erratically, but I don't think it would damage it in the process. I'd suggest installing a small auxiliary battery such as one of the the gel cell batteries used to power a kid's ride-on toy or something similar, and wire a power port to that. You could get several days' worth of use from a cell phone or other device before the battery would need recharging. A simple toggle switch could be used to isolate the second battery from the generator while electronic devices are in use. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If the GPS is on the cell phone, check your cell phone once in a while to see if it needs charged. Then charge it at home. Life is not that difficult. If you go on a long 8 day trip, charge it in the hotel room.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
A few weeks ago my electricity was off for 13 hours due to an ice storm. The only way I could charge my phone was in my old truck, in the cigarette lighter. On my trip to the homecoming I used it as well, no problems. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If 1953 panel has a generator, there's your answer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Was the engine running at the time of charging 1953 Panel?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A few weeks ago my electricity was off for 13 hours due to an ice storm. The only way I could charge my phone was in my old truck, in the cigarette lighter. On my trip to the homecoming I used it as well, no problems. Thank you, 1953 panel Other people have posted the same results. They have posted that USB charging adapters work fine in 6v-powered cigar/cigarette sockets. I am somewhat of a doubting Timoth, so I will eventually test this with an old/semi-lame iPad in my 6v Suburban. People have reported powering iPhones/iPads/GPS via a USB adapter in their 6v socket. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | If 1953 panel has a generator, there's your answer. yes, I'm running a generator, 12v. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Was the engine running at the time of charging 1953 Panel? Not at home when the electricity was off. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Still keeping Old Blue my '50 3600 bone stock, which means it's still got the 6v generator and 6v electrical system. I use the lighter socket for my TomTom GPS regularly as most all of the solid state devices actually only need 6v to operate them. Works like a charm. However, the Sony radio/cd player needs a voltage cube to up the 6v to 12v as does my SunPro tach. Denny Graham Sandwich, IL
Denny G Sandwich, IL
