0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Not quite really sure how I want to go about my electrical problems I have had in my truck, but I have been reading up on installing an alternator in my 12 volt 6 cyl. chevy. The question I have is the one wired alternator I am looking at, can I just run the wire off the alternator to the original wire that is coming from the voltage regulator Bat. terminal and will this effect my amp meter readings. I really don't want to run it straight to the battery unless this is the correct way to do it. Thank you......... | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Are you converting from a generator and voltage regulator system? Or an older alternator (Delcotron) to a newer alternator? Is your new alternator a modern internally regulated alternator? Give us some info here. Going form what to what.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I converted from a generator to an 1 wire alternator and ran to the BAT wire of the voltage regulator. (took voltage regulator out of the loop). It did not affect my amp meter. It still works like a charm. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | In about three nanoseconds there will be half a dozen doomsayers telling you that if you run alternator output through your ammeter there will be a conflagration rivaling the Chicago fire under your dash. Ignore them. Disconnect the "BAT" wire from the regulator and do a very good splice (preferably soldered) to the wire you're planning to use as the alternator output. An 8 gauge wire should be about the right size. Your ammeter and the rest of the elrctrical system will work exactly as it did with the generator. Disconnect and insulate the other two wires at the regulator and the other ends of them at the generator. The "armature" wire at the generator might be a little too light gauge to work well as an alternator output wire. Jerry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Has it been three nanoseconds yet (0.0000000003s)?🤔
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, it's been a nanoweek. With nonocomments. P.S. if you run your Alt thru the Ammeter, your shorts will catch fire. (shorts is a legit electrical term)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Thanks for all the help there Bolters, I have just had so much trouble with my generator voltage regulator combination. Maybe now once I purchase a one wired alternater, my problem,s will go away.... | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | As I have just learned... there is no such thing as a one wire alternator! I went through / before I discovered this! Search and you will find out more. I added the link to my issue.
Chris
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1262485/Searchpage/2/Main/184006/Words/%2BAlternator+%2B/Search/true/re-another-bad-alternator.html#Post1262485
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I switched for the same reason. I kept fighting with the Generator/Voltage Regulator combination. No issues since switching to an alternator. My generator was a 12v and not OEM. I had taken it to a long time shop that rebuilds automotive electrical components (starters, alternators, generators, etc...) and he did not know what it was from. I don't know if that was my issue but I am glad I switched. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Well about all I will say is if you are using a an alternator of 50amps or lower, you can easily get by with a 10 gauge wire, you can save a few bucks. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just to clarify. The link that was posted by ndkid and Tim has a post from me. If that is what ndkid is referring to when he says he learned there is no such thing as a one wire alternator, the post does say that there is a one wire alternator. It says the only true one wire is the alt advertised and sold as a one wire alt. It has been modified internally. All the rest are user modified in various ways, as explained. Adding just one hot wire to an SI is a one wire in name only. The diagram, posted by Tim in that post shows just one wire to hot. I don't know if the alternator he uses is a "factory" aftermarket one wire or a SI type just wired with one hot. I am pretty sure it's an actual one wire alternator. Tim knows what he is doing. Others need to investigate the issue. I did say that a true one wire "immediately starts charging".
I tried to point out in the other post that the word "one" is a misnomer in some cases. The word "one wire" can mean one wire visible anywhere on the alternator using an SI (the hot wire). It can mean one wire leaving the alternator after other jumper wires are installed. It can mean an actual one wire designed alternator. My "thesis" explains all that. There are so many wiring diagrams on the web regarding "one" wire alternators. I just recommend everyone study the issue before choosing one or the other diagram. The diagram posted by Tim, he describes as early internet, is only to be used on a true one wire alternator in my opinion. I believe that is what he uses it for. As I said, so many diagrams, just be careful. I know what Chris meant. It can be taken literally though.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I took it literally and found out! Thanks Bart! You said it better than me. I just don’t want anyone to learn my lesson the hard way with their kids on the side of a road or parking lot trying to get home. Chris
| | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I should have kept this a private message to Hotrod l....... and minimized the _ _., he told me this was going to happen. Again thanks for all your help..... | | |
