8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I installed an electric wiper motor after several years of fighting with my vacuum wipers on my 1952 3100. My problem with them is they are only wiping about 1/3 to 1/2 of the windshield. If I set them to park about an inch above the bottom of the windshield they only swing up to about the middle of the windshield. Does anyone know if there is an adjustment on the wiper motor to increase the travel? The instructions that came with it doesn't mention anything about such an adjustment, only how to adjust the parking. My motor housing has locking set screw at the bottom. I'm wondering if it would adjust the amount of travel. Neither the motor nor the directions indicate who the manufacturer is.
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to indicate who you bought it from, and that seller's part number.
Someone who has the same one might respond. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Is the motor mounted on top of the mounting brace? If not it should be.Also,the mounting brace is slotted,allowing the motor to be moved left or right for adjustment. | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I bought the motor from Classic Parts of America, item# 67-064B. According to the directions, the slots in the mounting brace are for adjusting the park position. I think the motor is mounted correctly. Everything lines up pretty well with the flat rods from the wiper arms. I just wish the motor shaft would rotate farther before it reverses direction.
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | BillyDon, Try a search within the electrical forum. How to adjust them has been answered. I'm not thre yet.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
