3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1264932 05/06/2018 3:04 PM
Hello Folks, My chevrolet 6400 speedo has stopped working, ive checked the cable all seems fine any body got any ideas, do the gauges pack up.Thanks Howard
Howardwade #1264967 05/06/2018 7:31 PM
Take the cable loose at the tranny. Connect your cordless drill to the end of your cable and slowly turn it while someone watches the speedo. If it doesn’t go up reverse your drill and try again. Still no movement of the needle, leave the drill connected and disconnect the cable at the gauge. Spin it up. If it moves your gauge is bad. If the cable doesn’t turn the cable is broken in the housing. Good luck.🛠
Howardwade #1265012 05/07/2018 1:34 AM
Reverse
Click
