| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 17 Member | | Member Joined: Jul 2003 Posts: 17 |
Life isn't like a box of chocolates... it's more like a jar of Jalopenos. What you do today may burn your [censored] tomorrow.
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Josh is it 6 or 8 lugs? 1/2 ton ( 6 lug) or 3/4 or 1 ton (8 lugs)?
Let us know.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jul 2003 Posts: 17 Member | | Member Joined: Jul 2003 Posts: 17 | 8 lugs and a 3/4 ton
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can put an ad in the swap meet section, or contact one of the on-line vendors. I'm sure Jeff at Bowtie Bits has some.
Fred 52 3600 69 C-10
#1267 07/12/2003 12:02 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Josh, have you tried calling Autozone to see if they have one? I think it's the same as the mid 50's to late 60's brake drums. David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I don't think so. The '49 had huck brakes.
Swap meet is a good start and I think I just read that one of the parts suppliers HAS replacement 3/4 ton brake drums. | | | | | Joined: Jul 2003 Posts: 17 Member | | Member Joined: Jul 2003 Posts: 17 | thanks for all the great info guys
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 |
