4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 32 | Hello Folks, My chevrolet 6400 speedo has stopped working, ive checked the cable all seems fine any body got any ideas, do the gauges pack up.Thanks Howard | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Take the cable loose at the tranny. Connect your cordless drill to the end of your cable and slowly turn it while someone watches the speedo. If it doesn’t go up reverse your drill and try again. Still no movement of the needle, leave the drill connected and disconnect the cable at the gauge. Spin it up. If it moves your gauge is bad. If the cable doesn’t turn the cable is broken in the housing. Good luck.ðŸ›
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
