0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
#1264892 05/06/2018 5:09 AM
Hello, I am after a bit of help please. I have recently rebuilt the brakes on my 6400 chevrolet, the four wheel cylinders at the back were overhauled as was the front. I also had the master cylinder overhauled. The hydrovac was also checked and cleaned. The problem i have is when i brake the brakes work very well but they pressure up and dont let off the pressure, all the springs are ok. If you crack a bleed nipple this releases the pressure.I have checked the rubber hoses all are ok. I even removed the hydrovac and stripped and cleaned again.Any help would be appreciated. The truck is a 52 model.
Howardwade #1264904 05/06/2018 12:38 PM
Did you use the same master cylinder? Some have a pressure release valve that must be removed, some don't. Also, your Master cylinder linkage may need to be properly adjusted for length.
Lots more pictures
Paul_WNC #1264928 05/06/2018 2:46 PM
hello Paul
Yes i am using the same master cylinder, I have managed to nail the problem down to the master cylinder when the brakes are stuck on you can crack the pipe that connects to the master cylinder and the pressure is released. I removed the master cylinder about 2 hours ago. and gave it a good clean blowing out all the holes with my airline. I then refitted and bled the entire system so far the brakes are not sticking. Fingers Crossed.
