1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
I am installing the full flow oil filter conversion on a fresh 302 GMC. I want to mount the oil filter adapter below the 12V alternator by fabricating a steel plate and welding it to the alternator bracket. Has anyone done this? seen this? and have the dimensions for the steel that I will weld on to the bottom edge of the bracket?
1946 GMC Project
"Back-in-the-day Restore"
How are you plumbing the filter lines? I don't know anything about the GMC engine oil systems, and I know enough about the Chevrolet oiling systems to be dangerous. I would be concerned about robbing too much oil from the crank shaft and cam bearings to supply the full flow oil filter.
Actually all the oil from the pump has to go somewhere be it with no filter, partial flow, or full flow filter. It's like turning a garden hose on a roof and saying less comes out of the hose if there are gutters. We won't let one of our engines go out the door without a full flow filter and a pcv valve. Oil will still be clear at 3000 miles rather than black at 1000. Fram filter in photo came with kit but it had a WIX when finished
[img]https://s31.postimg.cc/3t40a15ef/Billy_s_donated_55_016.jpg[/img]
Evan
Does that photo show a 1957+ 261?
1946 GMC Project
Tom, there is an article on http://inliners.org/ from 12 port news on the GMC conversion under Tech Tips.
BC
1960 C60 pasture art
Yep. Those were the steps I took - found in the link. My next step is locating the spin on oil filter adapter. Was wondering if someone located the filter below the alternator bracket, by welding a piece of steel to that bracket.
1946 GMC Project
1 Offline
That is how I mounted my 270 filter. Easy to get too and no mess when draining.You can always remote mount to the frame.
Joe
The older I get, I only want to work on older rigs.
