| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I am installing the full flow oil filter conversion on a fresh 302 GMC. I want to mount the oil filter adapter below the 12V alternator by fabricating a steel plate and welding it to the alternator bracket. Has anyone done this? seen this? and have the dimensions for the steel that I will weld on to the bottom edge of the bracket?
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | How are you plumbing the filter lines? I don't know anything about the GMC engine oil systems, and I know enough about the Chevrolet oiling systems to be dangerous. I would be concerned about robbing too much oil from the crank shaft and cam bearings to supply the full flow oil filter.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Actually all the oil from the pump has to go somewhere be it with no filter, partial flow, or full flow filter. It's like turning a garden hose on a roof and saying less comes out of the hose if there are gutters. We won't let one of our engines go out the door without a full flow filter and a pcv valve. Oil will still be clear at 3000 miles rather than black at 1000. Fram filter in photo came with kit but it had a WIX when finished [img]https://s31.postimg.cc/3t40a15ef/Billy_s_donated_55_016.jpg[/img]
Evan
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Does that photo show a 1957+ 261?
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Tom, there is an article on http://inliners.org/ from 12 port news on the GMC conversion under Tech Tips.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Yep. Those were the steps I took - found in the link. My next step is locating the spin on oil filter adapter. Was wondering if someone located the filter below the alternator bracket, by welding a piece of steel to that bracket.
| | | | | Joined: Aug 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 45 | That is how I mounted my 270 filter. Easy to get too and no mess when draining.You can always remote mount to the frame.
Joe
The older I get, I only want to work on older rigs.
