| | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | I am wanting to change the lighting to LED for the parking lights and also use the lights as part of the turn signals. Can someone that that traveled this path share their experiences? Thanks, 46Sparky | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I made my parking lights also turn signals. I did not use leds but nothing very magical about leds. The first thing to know is you need a different type of flasher as leds don,t draw enough current to heat the bi-metalic strip in a standard flasher. You then need to know the voltage 6 or 12. Leds are sensitive to voltage. Led arrays typically have a voltage limiting device and may have current regulation as well. You will probably have to mount an L bracket under the lens to hold the led array you choose. Depending on your turn signal set up and if you still want parking lights you might need two circuits. I made a new terminal strip for the fender a 4 pole. | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | One of the reasons I am considering the LED option is I’ve seen comments elsewhere the milky white glass used in the parking light bezel assembly reduces the lights brightness. Is that a correct understanding? I did look into the bulb options in the link Tim suggested. That looks like a viable parts source too. I am uncertain about the bulb size that was used for the 6 volt socket parking light originally. The socket is much smaller diameter than the tail lights. Also, the truck has been now been changed to a 12volt system. Thanks for the info and any additional comments, guys.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Not sure how you are wired now. The oem light switch turns on the parking lights at the position before the headlights and off in the head light position. If you're wired this way the best option is a two contact socket if your looking for an led bulb. This is what I did but other possibilities exist. | | | | | Joined: Jun 2005 Posts: 1,004 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,004 | Thanks for the info in this thread. Hope to get to this point this season!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | The wiring for the parking lights isn’t completed yet and the headlight/parking light assembly is on the bench. Wiring to the switch is installed and mounted in the dash. Access to most everything related to the lights and turn signals addition is readily available. I am thinking as a preferred option, of substituting use of the parking lights as originally used and use that hardware in as much as possible for turn signals instead. My preference would be to keep this as simple as feasible and avoid cutting etc. Ideally, the fix would a simple plug and play, much like the rear taillights I used.
I found the parking light bulb size for the original 6V system was. #55, 2 amp bulb. | | | | | Joined: Feb 2022 Posts: 1 Moderated | | Moderated Joined: Feb 2022 Posts: 1 | LED light bulbs have proven to be effective in all types of lighting. I doubt that now you can find many people who will stand their ground and say LEDs are overrated. Often you don't even notice when you use LEDs  Over time, they only get better and more interesting. I placed LEDs in the car, apartment, and even ribbons on the veranda https://www.vont.com/product/smart-strip-lights-led-strip-lights/. Because I really like that I can adjust the lighting modes that are convenient for my eyes.
