11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I converted my '42 to 12volt with an alternator. The 6v horn works for a toot or two and then dies. I've replaced the fuse each time but no success. Everything is new but I can't figure out what's wrong. | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Gerry, Maybe you need a resister in the circuit. This resister is used to drop the Voltage from 12Volts to something the horn can manage better.
I'd try a 1 OHM 50 watt resistor. The same thing veneers sell for the Fan circuit. Now running these in a fan circuit the resister gets very hot.
But in a horn circuit. Unless you really like to make noise......
https://www.classicparts.com/1941-54-Accessory-Voltage-Reducer/productinfo/24%2D996/
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Thanks bunch. I'll try it | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Replaced the fuse several times? Should we assume it is blowing these fuses each time? What else does the fuse serve? Do you have a 12V relay or a "good" relay. Did you just try grounding the horn case real good, disconnecting the hot wire, rig a jumper from the battery, and tap it on the hot terminal of horn a few dozen times?
History here says a resistor is not needed. The horn should work. If it blows a fuse, obviously it won't honk after that. So something is blowing the fuse. A resistor is not the answer. Test it as above, no relay, no fuse, no horn button, just tap and honk. Increase length of honk a little to two seconds-three seconds. Report results. BUT let us know about the fuse ASAP.
1. Corroded horn contacts. Burnt contacts. Broken contacts.
2. Bad relay.
3. A short.
4. What era is the horn from? 1942 or ?
5. Fuse too small.
"too much" voltage to horn is not the problem.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Now Gerry mentioned that the horn works intermittently or tow or three times before blowing the fuse. So I wanted to drop the Voltage applied. This assumes the the horn is 6 Volt.
Julian Carter
