Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 84 guests, and 3 robots.
Topics128,290
Posts1,058,566
Members48,492
Can some one tell me if the front splash apron should be screwed to the bottom of the grill and radiator baffle? My truck didn't have one when I bought it and the new splash apron and it doesn't have any screw holes. One other question is after I installed the grill the holes in the bottom of grill and the holes in baffle don't line up and the grill would have to be moved towards baffle about one inch to pick screw holes. Do you think I could have the wrong baffle. All the other holes in the baffle fit. What would you do to solve this problem. One other thing is the new splash apron fits the grill but does not fit the baffle.
Give me a few hours and I’ll check these parts for my truck, when I get out to the shop.. They are yet to be installed after paint completion. I will take some photos and send them to you via email. Send me a PM with your preferred email address.
Checked the parts, yet to be installed, today. All were previously assembled to check for fit etc. before painting. Everything fit fine then, so I offer the following based on that experience only.
As for the baffle size fit, I don’t know. If the apron lines up with fender fronts and the grill fits the apron then it might be the wrong baffle?
The front splash apron, baffle and grill have matching bolt holes and all assemble to the front fender and related sheet metal. I have photos of the parts in question showing the matched holes that will be emailed to you. I will try to figure out how to post these here as well. But...at my age patience and computers don’t play well together.
Here is a photo of the correct splash pan and the valance that connects the fenders together. Also, an exploded view of the grill pieces.
Harold
Harold
