3 members (Otto Skorzeny, Gray_Ghost, Phak1), 174 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#1262387 04/13/2018 10:32 AM
I am having a dilemma ... I have a 1952 chevy half ton panel, I would like to swap the rear axle, differential for a 3.55 or 3.73 set up and keep the stock column shift 3 speed transmission. I am thinking that if I could find a conversion for the yoke assembly on the transmission side of the drive shaft it would work. could any of you fellas help me out here? I have thought about just changing the ring and pinion but from what I have see it is very expensive. I am trying to find an inexpensive way that I can get my 52 panel to enjoy the left lane just a little ... or at least keep up with most of the traffic. without the engine screaming murder, I also need to note my 52 panel has a 1958 235ci engine. would the ring and pinion ratio alone allow me to reach my goal or is part of the problem in the ratios of the transmission? my pal has a 1997 rear end assembly he is parting out that he would sell me for 50 dollars.
What make/model/width 1997 rear end assembly?
Will you need new rear springs and hangers?
You'll need an adapted driveshaft?
It will be interesting to see if someone posts a way to use/convert your original closed-driveshaft transmission.
(please let us know what you get here)
Compare to:
- $350 plus delivery (maybe) for 3.55 R&P from [email protected]
- $450 delivered for 3.55 installation kit (parts you should also get new for you 1997 rear end assembly)
I'm thinking no easy way on the stock tranny unless he replaces it with the later design. I think the easiest is to dive into the stock third member and do a ring and pinion change to a 3.55. Today, I am buying a complete torque tube and rear axle assembly to do just this. Do a ring and pinion/bearing change in advance and get it all buttoned up then do the exchange in an afternoon. Used torque tube rear end assemblies you can get for at the most $25 some are free.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The 1954 3/4 ton with 3 speed used the same basic trans as the 1948-54 1/2 ton, except it had a open drive adapter on the rear.
These may be a little hard to find, but they are out there.
Here is a link to pictures of what it looks like.
My Blog
Awesome Dave. Nice post. That looks like the way to go then.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
thanks fellas . I appreciate your replies.
What that be the same for 1954 3600-3900?
Tim
I am not completely sure of your question Tim.
I think the 3 speed was only available in 1/2 and 3/4 tons.
My Blog
As usual, you are correct, Dave.
That 3-speed was standard equipment on 3100-3700.
A different 3-speed was standard for 3800/3900, and it was an RPO on smaller trucks.
In order for it to be RPO on 3100, it must have an a similar adapter on the rear?
http://chevy.oldcarmanualproject.com/chevyresto/54156.htm
