1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1262395 04/13/2018 12:21 PM
I converted my '42 to 12volt with an alternator. The 6v horn works for a toot or two and then dies. I've replaced the fuse each time but no success. Everything is new but I can't figure out what's wrong.
gerrys42 #1262397 04/13/2018 1:03 PM
Gerry, Maybe you need a resister in the circuit. This resister is used to drop the Voltage from 12Volts to something the horn can manage better.
I'd try a 1 OHM 50 watt resistor. The same thing veneers sell for the Fan circuit. Now running these in a fan circuit the resister gets very hot.
But in a horn circuit. Unless you really like to make noise......
https://www.classicparts.com/1941-54-Accessory-Voltage-Reducer/productinfo/24%2D996/
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
gerrys42 #1262546 04/14/2018 7:59 PM
Thanks bunch. I'll try it
gerrys42 #1262554 04/14/2018 9:14 PM
Sir Searchalot
Sir Searchalot
Replaced the fuse several times? Should we assume it is blowing these fuses each time? What else does the fuse serve? Do you have a 12V relay or a "good" relay. Did you just try grounding the horn case real good, disconnecting the hot wire, rig a jumper from the battery, and tap it on the hot terminal of horn a few dozen times?
History here says a resistor is not needed. The horn should work. If it blows a fuse, obviously it won't honk after that. So something is blowing the fuse. A resistor is not the answer.
Test it as above, no relay, no fuse, no horn button, just tap and honk. Increase length of honk a little to two seconds-three seconds. Report results. BUT let us know about the fuse ASAP.
1. Corroded horn contacts. Burnt contacts. Broken contacts.
2. Bad relay.
3. A short.
4. What era is the horn from? 1942 or ?
5. Fuse too small.
"too much" voltage to horn is not the problem.
gerrys42 #1262594 04/15/2018 1:29 AM
Now Gerry mentioned that the horn works intermittently or tow or three times before blowing the fuse. So I wanted to drop the Voltage applied. This assumes the the horn is 6 Volt.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
gerrys42 #1262630 04/15/2018 5:22 PM
Sir Searchalot
Sir Searchalot
10-4
