4 members (Shaffer's1950, Gray_Ghost, bucktruck, walter74), 84 guests, and 4 robots.
Topics128,129
Posts1,056,700
Members48,454
Finally found a center section with 4.11 gears! Tore it down to rebuild and inspect only to find some wear on the shoulder of the small pinion bearing housing. It looks like the outside races might have wore into the shoulder. Not a whole lot of evidence of the race turning though, oddly enough. Picture should be attached. Anyone see this before? Considering using another housing and putting my gears into it.
Thanks!
https://ibb.co/jnLvex
Riding in the Passing Lane
Try the bearing in the housing. If it fits snug or a little bit of looseness you can use some permatex Shaft & brg locktite. Its been a long time but it seems like there was a ledge on the bore where the brg fits.
1972 Chevy c10 Cheyenne Super
