7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible),
77
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | what is the correct paint color to painted underneath the hood? the body color or some kinda black? ALso how about color of bumper brakcets front and rear.My rear brackets appear to have been body color maybe since exposed and visible and the front ones look black Thanks in advance for the reply Ken | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Under hood, black, same as inner skirt, hood latch pan, etc. Bumper brackets, black also. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Thanks Denny, the old rear brakcets are painted same as body is it possible that since these are visible they would of been painted same as body? take care Kem | | | | | Joined: Mar 2007 Posts: 35 Junior Member | | Junior Member Joined: Mar 2007 Posts: 35 | Just about finished on restoring an unmolested '50 bolt---the underhood was black, the bumper brackets/braces were black under the heads of the bolts when we removed them from the frame.So--from the factory black & black.
"Age is only relative- - -It's just that some of us have more relatives than others"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I agree with that. Denny G
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Black with body color overspray around the edges. Bob | | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Thanks gentlemen I appreciate the help | | |
