8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | So, I was working on my 235 the other day trying to get it back together so I could get it back into my truck. The old exhaust manifold was in very bad shape so I decided to work on it. My plan was to replace all the studs as most of them were in very bad shape. I also wanted to try and free up the heat riser and get it working. Pulled out the torch and started heating up around the studs. Worked like a champ until I got to one of the studs that go through the intake and hold the two together. It was rusted down to just about nothing where they mated together. Needless to say that one snapped off. I did my best to drill it out, heat it up, and use a extractor to remove it but nothing I did would budge the bolt. Finally I decided that enough time was spent on it and it was time to shop for a new manifold. I could only find new manifolds from suppliers that fit the 216, but from what I read it was the same manifold. The only problem was that it cost about $225 and I wasn't quite ready to let go with that much right now. Off to craigslist I go. I did a quick search and found one locally that was still attached to the intake for $50. Messaged the seller and meet up with him to pick it up. Arrived at the pickup point, got out to give a quick hand shake, and looked in the back of his truck to look at the manifold. It wasn't there. He then stated that it was inside his truck. He opened the door to show me and I could not believe what I seen. The manifold was so clean he had it sitting on his seat and it looked brand new! Even the heat riser is complete and working. Things do seem to work out. Pic of manifold
Larry
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Great story. I love finding a bargain. That’s one reason why I enjoy swap meets so much.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Very nice, Larry
If you do not need the "heat stove" on the left of the exhaust manifold, take it off and keep it for someone who has an automatic choke carburetor that uses a pipe to that heat stove. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Good story. Don't you love it when things work out like that? | | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | I certainly do, its not everyday that it works that way.
Larry
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Nice to read this success story. Yep, the truck gods were smiling on you. | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 |
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
